Author Topic: Looking for blend pot. (MN taper, 9mm vertical) or slow fade x-fader schem.  (Read 744 times)
Offline frozenfrogzTopic starter
  • Having fun with Arduino and Raspberry Pi
Dear all,
I need to blend two audio signals and currently I am using just a simple linear potentiometer. However, I would prefer a solution with slow fade characteristic or at least equal power. For bass / guitar instruments there are a bunch of 16mm pots with MN taper available. I need something board mountable, 9mm vertical package (like ALPS RK09 vert. or Alpha RV09) with metal axis. These seem to be very hard to come by.
Can you advise for a manufacturer that has something like a dual non-parallel reverse log. in their portfolio?
See here for reference to MN taper.
Alternatively, can you point me towards a simple circuit that works with standard lin. or log. potentiometers and does not involve a bunch of extra components? I might be able to spare another one or two op-amps, but would prefer not to.
Thank you and kind regards!
He’s like a trained ape. Without the training.
