Author Topic: Looking for a manufacturer of flexible silicone wire (like on multimeter leads)  (Read 1407 times)
Offline BonsaiheroTopic starter
Hello,
If you know the test leads on Fluke multimeters or in fact on the 121-GW that Dave sells then you know what kind of cable I mean. Preferably I want the cable to be black and red and be attached to eachother (like speaker wire), but finding the wire seems tricky enough.
For reference, currently I'm using speaker cable 2x1,5mm^2 from Donne (a Dutch company), but this breaks too often internally, as the application is on a hand-held tool.
About half an amp  will pass through it at 14V.
Also can I cross post this to the buy/sell/wanted board?
Offline magic
Electro PJP makes nice silicone test leads, CAT rated, double insulated and everything. Distributors can be found.
I know that's not what you are looking for but it is similar to what you have seen on DMMs :)
Also:
https://www.tme.eu/gb/katalog/cables_38/?mapped_params=657:1451195;673:1451017;&s_field=artykul&s_order=ASC&visible_params=2,529,1181,665,32,657,2517,673,663,18,669,1335,661,672,423,667,681,683,2221,671,2206,678,2728,674,909,425,2171,2228,686,662,527,840,537,16,236,1362,736,426,668,1382,670,74,1775,731,2669,2968,2967,317,1605,2546,734,3076,3077,138,2705,351,1729,3078,14
It seems more like what you are looking for. Probably any distirbutor will have similar cables.
« Last Edit: August 08, 2019, 11:17:07 am by magic »
Offline KMoffett
Digikey in the USA sells internationally for many manufacturers. Do a parametric filter in their wire section. Select Silicon or Silicon Rubber.
https://www.digikey.com/products/en/cables-wires/single-conductor-cables-hook-up-wire/474
Ken
Offline ledtester
That's called zip cord.
Offline Jeroen3
  • Embedded Engineer
    • jeroen3.nl
As alternative, perhaps cable spiral wrap or high flexible PU cable?
Offline klunkerbus
  • Electrical Engineer (retired early)
Wire with a high number of fine gauge strands and silicone insulation is common in the radio control hobby. That may open up sources for you, although I don't recall seeing it available in zipcord style.
Offline NiHaoMike
    • Facebook Page
Look up "2 conductor silicone wire" on sites like Amazon.
Offline Warhawk
    • Personal resume
What you need is a quality silicon cable for R/C models of e.g. airplanes. Fist, go to the local hobby store and ask there. It comes in different thicknesses (cross sections). Our local store sources it here: https://m-el.eu
You will never look back.
A cheaper variant is this:
https://www.banggood.com/10m-Soft-Silicon-Cable-Wire-24AWG-Heatproof-Flexible-BlackWhiteRedGreenBlue-For-RC-Model-Battery-p-1394223.html?ID=228&cur_warehouse=CN
but it is nowhere close to ones from Muldental. The stuff from Muldental is pure copper*** and much dense.
https://rcpro.pl/eng_pm_Przewod-silikonowy-wysoko-pradowy-Muldental-11AWG-4mm2-czarny-9538_1.jpg
*** I was told that Chinese silicon cables must use tinning because of lower quality acidic silicone insulation.
I'd like to thank everyone for your replies, I will be using your suggestions.
Offline tooki
Reichelt sells twin silicone.
Offline dr.diesel
microflexwire.com also has similar super flex high strand count wire, known for high quality also.  You can get a variety of jacket material, silicone, FEP and others.
