I'm working on a small project where I need to power a device from a PC's USB.
This is the device I that I am working with:
It's an ESD tester to see if people are properly grounded. It runs on a 9V alkaline battery.
I previously added external circuitry to include a uC to get readings off of the device. The circuit also has opto-isolators to isolate the uC from the device. However, what happens now is that after a couple of months the battery does not have enough juice to drive the opto-isolators and so the uC won't be able to get the correct readers.
So, now I'm thinking of powering the device from a PC's USB port. I need to double the voltage from ~5V to ~10V to power the device while also supplying about 100mA. I also need to have the two isolated which pops transformers into my head which means I will need a transformer drive IC .
I've been having troubles looking for a good IC. The first one that popped up into my search was
TI's SN6501, but it doesn't seem to be able to provide enough current at ~9V. The
SN6505 and
LT3439 looks like they can do the job, but.. they are quite expensive!
I was hoping any of you guys would know of any good chips that will help do this job. Or if there's any other suggestions, that would be great!
