Author Topic: Mosfet Vgs +- rating  (Read 1147 times)
Offline CraftplorerTopic starter
« on: November 26, 2018, 04:28:26 pm »
i was looking at following mosfet from Fairshield https://www.mouser.de/datasheet/2/308/FDBL0065N40-1305438.pdf or from On Semi https://www.mouser.de/datasheet/2/308/NTMFS5C404N-D-1067128.pdf. Both have a Vgs of +-20V so does it mean that I can only apply 10V to the gate?
Offline ajb
Re: Mosfet Vgs +- rating
« Reply #1 on: November 26, 2018, 05:00:55 pm »
No, that means you can apply an absolute maximum of +20V or -20V to the gate, relative to the source.  I'm not sure how you got 10V from that.
However, it is not wise to use design your project based on absolute maximum ratings, as this leaves you no margin for error.  Electrical noise, or component tolerances, or other factors can easily push your device over the edge and cause damage to components.  Generally, MOSFET gates are driven to 10-12V in situations where you want hard switching and low on resistance.  This leaves a fair margin between the operating conditions and the absolute maximum ratings of typical transistors.
Offline Benta
« Reply #2 on: November 26, 2018, 05:02:24 pm »
It means you can apply +20 V or -20 V to the the gate without destroying the device.
Designing to the maximum rating is not a good idea, though, I'd go to +/-15 V tops.
Offline Benta
« Reply #3 on: November 26, 2018, 05:03:11 pm »
Whoops, simultaneous posting. At least we agree :)
« Reply #4 on: November 26, 2018, 06:03:55 pm »
Thank.
I was confused because opamp often say +-36V for dual supply but after i thought about it, it makes sense to me :)
And of cource i didn't want to drive the fet with 20V. The project ist powered by 11.4v
« Last Edit: November 26, 2018, 07:52:04 pm by Craftplorer »
Offline HB9EVI
« Reply #5 on: November 26, 2018, 06:17:03 pm »
you cannot conclude from an opamp to a FET - these are two complete different devices.
actually 36V is the absolute maximum rating for most jellybean opamps, the normal operational range is +/-15V
don't orient you on the absolute maximum ratings, they should never be touched under normal operating conditions
« Last Edit: November 26, 2018, 06:19:16 pm by HB9EVI »
Offline perieanuo
« Reply #6 on: November 27, 2018, 10:16:50 am »
Thank.
Hi, your 11.4 volts don't count.you can have a spike from another pcb sitting next to yours or induction or.. or..
That's why every power mosfet have some 12-15V zener protecting gate-source junction.don't miss this on power boards with mosfets as final stage.
Regards,pierre
Envoyé de mon iPad en utilisant Tapatalk
