Author Topic: Looking for an odd thermal pad to hold 10 transistors  (Read 962 times)
Offline cvancTopic starter
« on: July 24, 2019, 02:02:11 pm »
See photo, the pad is 10" x 1" and holds ten TO-247AC transistors (5x IRFP240 and 5x IRFP9240).
I know I could replace this with 10 discrete pads but if you know of a source for a long multi-transistor pad like the original I'd love to hear about it.  Thanks.
Offline ajb
Re: Looking for an odd thermal pad to hold 10 transistors
« Reply #1 on: July 24, 2019, 02:24:17 pm »
Lots of thermal materials are available in sheet form, just cut to size and whatever holes you need.  Some can even be laser cut (like Laird's kapton-based thermal films) if you have access to that sort of equipment somewhere, but generally an xacto knife will do the job.
If the transistors are insulated packages as in the photo, you don't necessarily need an isolator, silicone thermal paste (or equivalent) to ensure good thermal contact is all you need.
Offline kjr18
« Reply #2 on: July 26, 2019, 12:10:10 pm »
These transistors on photo do have a metal thermal pad on it's backside, so isolation is still needed.
Online Siwastaja
« Reply #3 on: July 26, 2019, 01:10:57 pm »
Screws will happily penetrate most thermal pad materials, so I don't usually bother in ordering custom cut, or manually cutting.
