Hi
If you cant find a programmable device, you could put a DAC in the feedback loop. Instead of using a Vref voltage, you use the feedback output of the converter. The DAC then acts like a digital controlled potentiometer. You could also try digitally controlled potentiometer devices, often used in audio equipment.
Dazz
