Author Topic: Roughly dropping voltage to charger IC  (Read 1368 times)
Offline CheekyRobotTopic starter
« on: July 09, 2015, 03:05:25 pm »
I need to charge a 1cell 2000mAh Lipo on my device. Normally, it's strapped to a vehicle and can keep itself topped up using the vehicle's battery and I'd like to be able to charge it via a USB charger when it's taken off.
I might use something like a MAX1551 http://www.farnell.com/datasheets/1675715.pdf It gives me a dual input from USB as well as an ac adapter input which I could connect to the vehicle's 12v battery to keep the LiPo topped up.
Now... what this question is about is whether it's a better idea to just use a resistor to drop the 12v input from the vehicle's battery to the 4-7v that the charger IC would like (23r ish at 1.8w if I'm drawing the 300mA that the datasheet suggests) or to pop in a regulator. I'm a little loathed to use a 7805 or similar given how inefficient linear regulators are or should I go all fancy and put in a buck regulator? (expensive?).
The device itself only draws about 200mA absolute max spike current, so we're not really pushing a lot of power about here.
Any thoughts or suggestions?
Offline Zero999
  • 0999
Re: Roughly dropping voltage to charger IC
« Reply #1 on: July 09, 2015, 03:11:47 pm »
If you want cheap and cheerful, you could use a Black regulator:
http://www.romanblack.com/smps/smps.htm
« Reply #2 on: July 09, 2015, 03:33:20 pm »
Cute! Though that big-old inductor is gonna kill me. This all fits into a VERY small box ;)
