I have a Voltage Controlled Oscillator (VCO) in my hands that's part of a modular synthesizer (audio) and I am really trying to understand how it works. After hours of reading on op-amps, comparators and other related circuits I understand a lot of aspects of the design but I am struggling with the most critical part, the actual oscillator.
To make things a bit spicier I am working from schematics I drew from studying the PCB closely without the luxury of being able to remove components. Mistakes are likely even though I tried to double check things.
The schematic is attached below.
Questions:
- The U106/U104 pair seems to be the heart of the beat; what makes them oscillate? Of course Q101 is here to throw a wrench in my understanding of the picture.
- I am really thrown off by the U102A / U102B NPN pair (Analog Devices SSM2210, see datasheet below). I've cross-checked their connections a few times and re-checked the datasheet, I really don't understand what role they play and how they can control anything.
- U101 and its networks seem to be a summing amplifier designed to collect the various tuning inputs to adjust the frequency. But how does its output do anything, being tied to the base of U102B?
- Speaking of U101, I have trouble reading the value of its feedback resistor R107. "orange orange red black red". In one direction it's 332 ohms at 2%; in the other direction it's 202K at "orange"% which apparently "orange" is not a thing for a tolerance spec. And it's probably not 332 ohms because a measure in-circuit is about 2K and it couldn't be higher than its actual value, so that doesn't work. Mystery!
The PCB is powered by +12V (VCC), -12V (VEE) and GND.
The two input signals "SYNC_IN" and "UNUSED_1" are optional inputs on the PCB and they don't need to be connected for the circuit to oscillate so I am ignoring them for now.
The two potentiometers RV1 (FINE) and RV2 (COARSE) allow for fine / coarse adjustment of the frequency. It can go from below 1 Hz to well above 10-15 KHz.
The SAW_SIGNAL output routes through one more unity-gain LF351 amplifier (with Rf = Rin = 22K) before reaching the output jack that can be used throughout the rest of the synthesizer; I have omitted this part on the schematic.
Datasheets:
