Hi all,
New to this forum... please be gentle. Probably could have put this in Beginner or Vintage Computing but overall seemed better here.
I've been working on a project to remake keyboards for the Amiga 1000 computer. I'll add details below for those interested but for now I'm at the stage where I am looking for components to build the PCB.
I'm a noob when it comes to selecting and ordering components, but I'm getting the impression that tantalum caps are now hideously expensive. There is one tantalum capacitor on my original keyboard marked with 25 on the front and N2 on the back which seems to be a 22 uF 50V cap on the schematics. It runs from one leg of the timing crystal to ground. Unless I've misunderstood something it looks like these go for $6.62 each on digikey, whereas equivalent ceramics are around 0.40. So I'm wondering if I can do a swap? (but also after some confirmation of my suspicions that this is a known issue with tantalums these days.)
Thanks,
Nick (ncstebb)
More details if you're interested.
- specs I'm referring to are here:
https://deskthority.net/wiki/images/3/32/Commodore_Amiga_1000_keyboard_schematic.jpg - I've modelled the original keyboard case and after several prototypes have it working nicely when resin printed.
- I've modelled the keycaps using both mitsumi and cherry mounts
- I've traced the artwork and have produced engraved keycaps which I can resin print, paint and sand leaving something fairly close to the originals
- I've modified the pcb to use cherry compatible switches and have just got 5 of these back from JLCPCB
- here is a photo of where I'm at:
https://drive.google.com/file/d/1_Vf5euy-9QX78yrR9vyTgbZR97zGnUdd
