Author Topic: Looking for High Current capable connector ( ~100 Amps) for PCB  (Read 1851 times)
Offline gmandaTopic starter
So I have a battery protection circuit on a PCB (under/over voltage and overcurrent). I'm looking for the name of the connectors similar to the ones shown in the picture. I just cant find the name. Can anyone help me pls?
Offline jbb
Re: Looking for High Current capable connector ( ~100 Amps) for PCB
« Reply #1 on: July 21, 2019, 11:02:19 pm »
I’m not sure what the part is called, but the picture seems to be a evaluation board. If you have a look around, maybe the evaluation board maker has a Bill Or Materials available? That would contain the connector details.
« Reply #2 on: July 21, 2019, 11:04:40 pm »
Sorry i forgot to mention - yes it is an evaluation board but it has no BOM :(
Offline ahbushnell
« Reply #3 on: July 21, 2019, 11:05:48 pm »
That is a wire lug.
Here are some examples on McMaster Carr.
https://www.mcmaster.com/lug
Here is an example that looks similar but is probably larger than yours.
https://www.mcmaster.com/6920k35
What gauge wire do you plan on using?
The following users thanked this post: gmanda
« Reply #4 on: July 21, 2019, 11:12:17 pm »
THANKS A LOT my man!!!!! Yeah I finally could find several parts. Digikey being my preferred vendor, I found a whole section of these (https://www.digikey.com/product-detail/en/panduit-corp/LAMA2-14-QY/298-10109-ND/317639)
Yeah i think I will go with something like 2-4 AWG.
Offline digsys
    • DIGSYS
« Reply #6 on: July 21, 2019, 11:42:50 pm »
Quote from: gmanda
THANKS A LOT my man!!!!! Yeah I finally could find several parts. Digikey being my preferred vendor, I found a whole section of these (https://www.digikey.com/product-detail/en/panduit-corp/LAMA2-14-QY/298-10109-ND/317639) ...
Well, that saved me time :-) I was about to look for the exact same thing today. I hope you didn't buy them all !! Leave me some
Offline BrianHG
    • LinkedIn
« Reply #7 on: July 22, 2019, 03:24:21 am »
If you really want to save money, go here:  100pcs, 38$
https://www.ebay.com/itm/100pcs-S4-Dual-Rated-Single-Wire-Mechanical-Lug-4-AWG-IHI/223320006389?hash=item33fee8def5:g:9NkAAOSwUpFcN6rI
Scroll down and you'll see all the available sizes and quantities.
Offline daqq
  • Country: sk
    • My site
« Reply #8 on: July 22, 2019, 05:34:50 am »
Wurth has something similar:
https://uk.farnell.com/wurth-elektronik/7461098/shank-m6-full-25pin/dp/1821290
https://uk.farnell.com/wurth-elektronik/7464000/terminal-pcb-1-47mm-press-fit/dp/2748952
Officially they are press fit parts, but you can solder them as well (it's what I use them for).
Offline digsys
    • DIGSYS
« Reply #9 on: July 22, 2019, 07:38:42 am »
Quote from: daqq
Wurth has something similar: ... Officially they are press fit parts, but you can solder them as well (it's what I use them for).
oooooo nice ... just ordered some :-) I love this forum
Offline daqq
  • Country: sk
    • My site
« Reply #10 on: July 22, 2019, 08:00:41 am »
Quote from: daqq
Yeah, it's a nice series of parts. There are many more variations on them:
https://www.we-online.com/web/en/electronic_components/produkte_pb/produktinnovationen/redcube.php
Though the SMD versions seem fishy to me.
