Author Topic: Looking for li-ion charger ic with over discharge protection  (Read 1016 times)
Offline Tada9Topic starter
  • Country: cz
« on: April 27, 2019, 01:13:20 am »
Hi guys,
I am looking for single cell li-ion charger ic with over discharge protection for my project. I would like to avoid using 2 separate ICs for this.
I was able to find some ICs that have both functions(for example STNS01), but they are way too expensive and have many features that I don't need. I really only care for the charging and protection. Ideally, the cost shouldn't exceed ~1USD.
Any ideas?
Offline Peabody
Re: Looking for li-ion charger ic with over discharge protection
« Reply #1 on: April 27, 2019, 02:15:48 pm »
You might look at the LTC4054.  It may be over your budget, but I think it provides charging and over-discharge protection.
Offline OM222O
« Reply #2 on: April 27, 2019, 02:39:59 pm »
you might want to look at the chinese go to chip: DW01  :-DD
here is a link to the datasheet: https://cdn.sparkfun.com/assets/learn_tutorials/2/5/1/DW01-P_DataSheet_V10.pdf
you just need to add an additional duel fet in order to allow the IC to disconnect the battery in fault conditions.
Edit: you can buy 20 of them for 1$ on aliexpress:
https://www.aliexpress.com/item/FS8205S-DW01-8205A-SOT23-6-lithium-battery-protection-IC-chip-DW01A-FS8205S-8205S/32881501475.html
« Last Edit: April 27, 2019, 02:43:46 pm by OM222O »
  • Country: cz
« Reply #3 on: April 27, 2019, 07:29:00 pm »
Unfortunately, LTC4054 is only a charger and DW01 is only a protection circuit. I am looking for combination of both to save on part count, space and complexity.
« Last Edit: April 27, 2019, 08:32:09 pm by Tada9 »
Offline OM222O
« Reply #4 on: April 27, 2019, 07:40:16 pm »
did you look at the data sheet for the DW01?
It both provides charging cut off (4.25V) and all sorts of protection ... you seriously can't get much better than that. there's a reason all chinese products use it.
