Author Topic: breadboard with holes in it  (Read 340 times)
Online coppercone2Topic starter
« on: December 22, 2024, 07:15:38 am »
sometimes I don't want to trim the leads of the parts but I want to use a breadboard.
is there a breadboard with holes in it so you can push down parts so you just get a bunch of stubs. it would stand on posts
Offline ebastler
Re: breadboard with holes in it
« Reply #1 on: December 22, 2024, 07:35:50 am »
Aren't the typical n*(5+5) pin plastic breadboard modules all open at the bottom, until the manufacturer mounts them on a baseplate or sticks on some padded adhesive tape?
Offline Ian.M
« Reply #2 on: December 22, 2024, 07:59:15 am »
No, because the contact spring strips have closed bottoms.  Without the tape/foam, a too long component lead can push the contact strip out of its slot.
The following users thanked this post: ebastler
Offline ebastler
« Reply #3 on: December 22, 2024, 08:09:09 am »
Duh, you are right of course. It's been too long since I took a few of these apart to build some breadboard watches.
« Reply #4 on: December 22, 2024, 08:22:44 am »
I have seen shitty powerstrips built in a way that could work
