I have a pair of 42cm dia loudspeakers in the boxes of dimension aprox 70cm x 50cm x 30cm....no label with spec anywhere, i was told its aprox 300W a box...but who knows....
i have a power amplifier of 2 x 100W RMS...tried up to max and seems speakers can handle a lot more power.....question is how much more?!?!
i have no higher then 100W amplifier and i would like to find out what is the actual max power of loudspeakers it can handle till distortion begins (read maximum useful sound power)
i know how to measure V x A...sending 50Hz audio signal through the power amplifier and make the readings on the speaker itself....but again, with just a 100W of power i cant reach its max and i believe with 100W RMS i am driving it it looks like speakers are on half of its possible power they can handle....
i was thinking about sending a sine wave signal from a power amplifier and on other side of speaker put some microphone connected to a probe of oscilloscope so i can receive the sine wave signal from the speaker through the air....and monitor the shape of sine wave....raising the input power to the speaker and monitor the sine wave on scope until sine wave form becomes distorted what means the speaker has reached its max and became unstable, so its membrane cant follow the sine wave signal anymore logically....
but again, for that method i need a higher power amplifier...which i dont have but 100W max....grrrr
so i got some other idea...alternative idea you might be all laughing now....but keep in mind, this isnt a precise measuring, but only aprox...if i get the precision of + / - 15% i would consider it awesome....
i was thinking measuring the membrane travel height moving it by hand (with some reasonable force pushing it) to some max and reading the measure with the micrometer lever dial gauge that is used in machining (i have several i am using on my drilling/lathe table) ...set it up and then by using an AC transformer of high power simply connect the transformer to the speaker starting from 1 Volt and stepping it up by 1 volt till i reach the max membrane movement (i have a lever that can make a HOLD effect at the max peak)...so when i reach the max membrane movement compared to measuring by hand moved, that would be the max power this speaker can handle....of course by measuring the Voltage and Current what makes the max movement of membrane....
all measuring would be like less then a second....to avoid burning the coil of speaker....but more then enough to make the membrane do its movement...so that result of Wattage i can reduce for like 20% to be sure the permanent but maximum possible power that can handle
alternative method is, measure max membrane movement by hand and then measure it when 100W is applied and get aprox possible power it can handle...but then again the gain is exponential so the calculation might be much worse then with the transformer source method i guess....
after you calm down of
all i could ask is; any other suggestion?!
