Author Topic: Display - Cheap and Large  (Read 858 times)
Offline siderealTopic starter
« on: November 21, 2021, 09:16:23 pm »
Hi
I am looking forward to build a medical routine and tracking unit for myself.
I want to have nice wall covering visualizations. This is my idea :
I like the modular nature of things, and will go that route.
As you can see, I need 56 Screens.
It'd be very cool to have something like this Sony Ericson Xperia Pureness :
But such things are too difficult to read (low contrast).
I have considered :
https://www.exp-tech.de/displays/e-paper-e-ink/8895/waveshare-2.7-e-ink-raw-display-264x176?c=1424
But doing this  means i will have to shell out ~ 600 € + the SPI drivers. But this is too expensive. I need some cheaper alternative.
What are my options ? My requirements are :
  • Size : 3 inch to 5 inches
  • Drive Over SPI, hopfully over Arduino. If not possible, then I am open to ESP / STM32 as well
  • Low power consumption : <0.5 mW. If at all not possible - then i can work my way up to 10 mW max (yes, 3 orders of magnitude change)
  • Resolution : around 170x170 or more
To reiterate, Cheap and low power are also important to me. I am willing to shell out about 4-6 € per unit.
I look forward for your recommendations. Thank you.
-Sideral
« Last Edit: November 21, 2021, 09:22:00 pm by sidereal »
Offline Berni
  • Country: si
Re: Display - Cheap and Large
« Reply #1 on: November 22, 2021, 06:27:15 am »
Yep sounds like you instead want to get a large TV or one of those laser micro projectors. Likely a cheaper solution and you can run it from the HDMI port on a raspberrypi
