Author Topic: Motor/generator  (Read 555 times)
Offline tropesTopic starter
Motor/generator
« on: July 10, 2021, 10:34:16 pm »
I have a driven shaft turning a PMSG connected to a three phase rectifier creating a 24 volt DC output current.
http://lightswitchracing.com/55W.MOV
I also have a motor controller connected to the PMSG using 24 volt DC input, that turns the PMSG shaft at 350 rpm.
I have been disconnecting the rectifier and connecting the motor controller to switch from generator to motor.
Is there a way to switch the PMSG from a generator to a motor without disconnecting one and connecting the other?
« Last Edit: July 14, 2021, 09:50:55 pm by tropes »
Online NiHaoMike
    • Facebook Page
Re: Motor/generator
« Reply #1 on: July 10, 2021, 11:14:05 pm »
You need a motor driver that supports regeneration.
Re: Motor/generator
« Reply #2 on: July 10, 2021, 11:24:33 pm »
Thanks, and where would I find this motor driver that supports regeneration?
Online NiHaoMike
    • Facebook Page
Re: Motor/generator
« Reply #3 on: July 11, 2021, 01:47:49 am »
Check the documentation to see if there's a mention of it or something like "regenerative braking".
Re: Motor/generator
« Reply #4 on: July 11, 2021, 01:50:38 am »
Thanks, I did and found info.
