Hey all :-)
I am working in a project for a mate, he wants to install a white LED inside a 3mm diameter tube to shine through some little bead type things. Apparently they have really small images inside them.
The size isn't the issue, the problem is he has to use a 3mm diameter battery, which there aren't many of.. One he has found is a lithium cell used in floats, it's a 20mah battery at 2.5 - 3v. The recommended current draw is 500 micro amps.
Does anyone know of an LED that will work well enough at that lower current with a Vf of around 2.5v?
I have found a few but not sure how well they will work that low down.
