Author Topic: Low Frequency Flicker Noise Source  (Read 3583 times)
Offline coppercone2
Re: Low Frequency Flicker Noise Source
« Reply #25 on: May 26, 2023, 04:55:37 pm »
I don't know, that might be susceptible to tampering by increasing radiation bias though
Online mawyatt
« Reply #26 on: May 26, 2023, 05:03:33 pm »
Curious if the neon bulb current flickers along with the light output?
If so, one could place a small series resistor (maybe AC couple) in the ground leg of the bulb and electrically "see" the random noise result, or maybe just the ON voltage across the bulb (AC coupled).
Best,
~Wyatt Labs by Mike~
Online David HessTopic starter
  • DavidH
« Reply #27 on: May 26, 2023, 05:31:48 pm »
If you just drive the neon bulb into breakdown it operates as a noise source anyway.  There were special tubes which used this mechanism.
