A common modern low leakage diode is BAV199.
If tested low leakage is required, 1N4117 or 4118 JFETs are an option too.
Another point is keeping the temperature low and the voltage small, by bootstrapping the diodes.
Usually the diodes are not causing much noise, but they can cause leakage - so it depends on the impedance level.
