Hi everybody and a happy new year.
I'm currently designing a controller for my two drainage pumps that keep my basement turning into an unwanted swimming pool.
Both pumps are on their own circuit breaker, and I want to detect if that breaker has triggered. So, I need to detect whether AC is present.
Now, there is the classic way of taking a big resistor, or capacitive dropper, and triggering an optocoupler. But that will constantly piss away a couple of mA. Something rubs me the wrong way to waste a couple of kWh per year just to detect if voltage is present. There must be a better way.
I do have a current sensor in place that monitors the power consumption of the pumps and checks them against spec to detect a failing or blocked pump. But that only is useful if the pump is running, and that's not always the case. It runs 2-3 times per hour for a couple of minutes at most.
So, what's a better and efficient way that doesn't use more than a couple of mW?
