Just wanted to show off my new power supply build.
It is heavily inspired by the power supply build in the videos by Dave Jones. And i have thrown in a couple of ideas of my own.
It is using an lm338 regulator powered off a laptop brick. The cooling will be provided by an old Intel CPU heatsink, i have those laying around all over the place.
I'm using a 555 negative voltage charge pump to deliver a negative voltage rail for driving this down to 0 volts.
Had to do some dicking around with the constant current circuit. Connected the emitter of the current control transistor to the negative rail.
DUH, now i had current flowing through the base because of the voltage difference.
Connected the supply to the current sense opamp to the negative rail . This also made me able to read lower currents, as the output does not go all the way to the ground rail.
The voltage reference is a REF02, and it feeds into the inverting input of an opamp to generate the negative voltage reference. This feeds into a 6.8k resistor before it goes to the pot.
I have also ordered an AD620 to see if i can improve the current shunt accuracy. It probably doesn't matter in this setup anyways, but it's nice to have something to tinker with.
There's also an arduino nano in there for reading voltage and current, and maybe eventually including logging, wireless etc.
The protection diode is a beefy SB560 i had laying around; 5A, 150A peak. Should protect it from most anyting.
I have also designed a case in solidworks that i will 3d print.
BUT looking at datasheets, it looks like the LM338 has higher thermal resistance than the LM317 (4 vs 3 degrees) that will mean less current at lower voltages. I'll have to test it out, LM338s are dirt cheap! Nothing like the LT3080 which costs about as much as this entire build.
