I am working on a circuit to sense very small infrared pulses. I am using a TAOS TSL267 for a sensor. It's a got the PIN diode and transimpedance amp in one device. I am using four of those summed together. Then, I want to pass the signal to a NE592 video amp to bump up weak signals. I will be configuring the amp as single sided instead of differential input.
I am looking at the NE592 datasheet, but I am very new to this type of a device. Looking at some of the example circuits, I am trying to figure out exactly how to get the signal into the 592 so it will be happy.
In the attached image, what are the 51 ohm resistors on the left side (the inputs) for? I know it's a basic question, so please pardon my ignorance.
