Author Topic: Low profile Ferrite core suggestion  (Read 829 times)
Offline ali_asadzadehTopic starter
« on: April 01, 2019, 07:24:25 am »
I want to design a low profile product, so I need some ferrite core and bobbins to replace EE13 and EE16 transformers, Do we have something with low profile? Ideally if I can find something with 5 or 6mm height max it would be very nice. Also do you know some good and reliable chinese manufacturer to tell?
ASiDesigner, Stands for Application specific intelligent devices
I'm a Digital Expert from 8-bits to 64-bits
Offline T3sl4co1l
    • Seven Transistor Labs
Re: Low profile Ferrite core suggestion
« Reply #1 on: April 01, 2019, 07:29:16 am »
Tons!  Look at any catalog.  ELP, planar E and ER, and I forget what others.  SMT bobbins (vertical cores with low profile; horizontal cores with low width) are common, or you can make your own from PCB, usually with 4+ layer boards (planar magnetics).
Seven Transistor Labs, LLC
« Reply #2 on: April 01, 2019, 08:20:44 am »
Thanks Tim for the feedback, do you have a favorite manufacturer or part number? what about chinese manufacturers? do we have a parametric search engine out there? PCB sound nice, but a flyback transformer with about 80 turns of primary!Is it doable?
« Last Edit: April 01, 2019, 08:22:42 am by ali_asadzadeh »
Offline TimNJ
« Reply #3 on: April 01, 2019, 05:51:42 pm »
For a traditional wire-wound transformer, finding an appropriate core/bobbin combination with 5 or 6mm height sounds tricky. 10mm might be a little more realistic. Maybe take a look at EFD15.
