Can you post results of the detector portion?
There's a short video on page 1 showing how it works, but other than that - I can get around 0.9-3cps/uSv/h(compared a few other meters) with a 10x10x30mm CsI:Tl crystal and the MicroFC-60035 SiPM from ON Semi(SensL), depending on how touchy I get with tweaking SiPM bias and amp gain. Not particularly reliably, but a prototype is a prototype.
If it is for the whole system
PSU and amp only at the moment. Given the recent suggestions, I should be able to get it much lower, which will get it closer to the Radiation Pager lifetimes, but much smarter.
AFAICS simply using a large enough anode resistor (which increases the pulse duration) with a TLV7011 will allow detection with very low power consumption (5 uA for the comparator).
Can you elaborate? The SiPM will go through a MIC860 to get amplified first. I don't think the TLV7011 can operate at an extremely low voltage(3-25mV pulses).
Use an OV-7604-C7 oscillator driving a BSS123 and some large inductor (1-100 mH) for a boost converter to get 30V. With an ultra low power comparator like the TLV7031 to turn the output of the oscillator on or off and to pull the gate down through a diode when it's turned off. This would have an irrelevant quiescent current of around 1 uA.
That is a great idea! I'll throw something together when I get the time, working on a different project right now(DIY SEM, no microamps required here...).
This could also be very useful for a high voltage SMPS for generic geiger-muller tubes, since the plateaus are much bigger there(10V ripple @ 410V is acceptable). A GM tube power supply that pulls <10uA on average would be a hit as well, though there's a bigger issue of high voltage measurement and hooking a boost up to a multiplier there.
