Author Topic: Low side relay switching overvoltage protection  (Read 1224 times)
Offline golf32Topic starter
« on: February 22, 2023, 07:37:47 pm »
I have a circuit where I need to switch an external relay via an optocoupler. It would be really convenient if I only had to connect relay low and ground as shown in the schematic:
In this case the relay would have +24V from another source and the opto would open the low side path.
If this were the case, I wouldn't have access to the high side of the relay to put a flyback diode. I know many relays (particularly the DIN mount relays which I am targeting) have internal flyback diodes, but I want to ensure you can never damage the opto.
The first thing that comes to mind is adding a zener diode across the collector and emitter of the transistor. However, in my simulations, the current is much higher than the typical flyback configuration. I've also never seen this configuration before, and a cursory google search has come up empty handed on other techniques.
Any advice? Thanks in advance.
« Last Edit: February 22, 2023, 07:41:02 pm by golf32 »
Re: Low side relay switching overvoltage protection
« Reply #1 on: February 22, 2023, 08:20:37 pm »
Zener diode will work, but better is a transorb or MOV, rating determined by the breakdown voltage of your open collector output, not the relay supply voltage. Placed across the transistor collector to emitter to clamp the maximum voltage there to under the maximum for the transistor, and od course it should be well above the supply voltage. Typically your transistor will be rated for 100V or more, so a clamp of around 48V will work fine.
The following users thanked this post: golf32
« Reply #2 on: February 22, 2023, 08:31:07 pm »
Of course, a MOV makes total sense. Thanks, I think that answers my question.
Online Benta
« Reply #3 on: February 22, 2023, 10:26:15 pm »
SeanB's reasoning is sound, and the choice of 2x relay coil voltage as well. That will reduce contact arcing/burn.
Whether you choose a MOV or a TVS is not really important.
