Author Topic: lowering a.c. voltage output for power supply  (Read 1307 times)
Offline mgvguyTopic starter
« on: February 11, 2020, 07:00:12 pm »
I have a device that requires 9v a.c. and rated for 2.1 amps.  I thought I could modify the output of either of the following:
1.) a power transformer that outputs 24 v, 50 va
2.) a power supply walwart - output 15v a.c., 1.5 amps
Is there a simple way to do this - any schematics/component values possible?
Thanks!
Online Ian.M
Re: lowering a.c. voltage output for power supply
« Reply #1 on: February 11, 2020, 07:30:51 pm »
Is there a simple way to do this ...?
No!
If it *NEEDS* AC, then there is no easy way to change the voltage.  Even if the transformers have a dual voltage primary, going from the 120V connections to the 240V connections while keeping the supply at 120V would halve the output voltage, and as neither of them is 18V to start with, you cant get 9V from them so it wouldn't help.
Offline KaneTW
« Reply #2 on: February 11, 2020, 07:54:09 pm »
Yeah, there's a simple way. Go on Amazon and buy a 9V AC wallwart.
If you have a transformer with an appropriate winding ratio lying around, sure, you could do that. If you don't, just get the wallwart.
Offline Prehistoricman
« Reply #3 on: February 11, 2020, 07:55:58 pm »
Modifying transformers isn't particularly easy, especially at wall-wart sizes. Even if you did decrease the voltage of option 2, you wouldn't have enough current capability.
For option 1 you would probably have to find a way to convert the unit to accept DC. That could be easy or it could be hard - completely depends on the circuit within. Or you could get a DC power amplifier to output 9VAC lol
Offline mariush
« Reply #4 on: February 11, 2020, 07:58:59 pm »
I would recommend actually buying a transformer, it's not expensive.
9v 2.1A is around 20VA, so anything higher than that would work.
Ex.
27VA  9v/18v https://www.digikey.com/product-detail/en/hammond-manufacturing/266K18/HM2140-ND/2358044
25VA 9v/18v https://www.digikey.com/product-detail/en/triad-magnetics/VPT18-1390/237-1323-ND/2090061
Get the toroidal transformer, put it in a plastic project box, install a IEC C7 connector on the box and the cable with barrel jack connector or whatever your device needs on the other side and you're done.
If you want to modify one of the transformers, probably the easiest would be to get the 15v AC 1.5A one and unwind the secondary winding, measure the length and then cut a bit of the wire to match the 9v ... you'd get 9v 1.5A ... hope that your device doesn't actually need 2.1A and is happy with 1.5a
To increase current, you'd have to mess with the diameter of the primary and secondary wires, calculating magnetic flux and other crap.
With the 24v transformer, maybe you could unspool the 24v secondary winding and make 3 x 8 secondary windings and parallel them and hope that your device will be happy with 8v AC
Or maybe make 2 x 9v secondary windings and parallel them.
Online Gregg
« Reply #5 on: February 11, 2020, 09:06:25 pm »
In the past (carefully avoiding mentioning how old I am) a lot of devices used wall wart style transformers with AC output; things like dial up modems, phone answering machines etc.  A lot of these wall warts have ended up in thrift stores and are available inexpensively; many are even UL listed.  A trip to some thrift stores is also entertaining; take a magnifying glass along to read the tiny specs on some of these devices if your vision isn’t the up to the task.  Many of the old school wall warts have small fuses inside that can be changed if they have no output.  Also be aware that open circuit voltage on a simple transformer rated for 9V and 2 plus amps will be much higher because the transformer voltage is specified at the specified current.
Online NiHaoMike
    • Facebook Page
« Reply #6 on: February 12, 2020, 12:57:02 am »
Check if the device actually needs AC or if DC will also work.
Offline David Hess
  • DavidH
« Reply #7 on: February 13, 2020, 12:42:09 am »
The current is a little low but if you have a 24 volt AC output and a 15 volt AC output, then wiring them in series and anti-phase will produce 9 volts AC.
Offline sam[PS]
« Reply #8 on: February 28, 2020, 04:54:29 am »
That's assuming there is no capacitive effect there to screw your phase alignement. i.e. probably not a good idea in real world.
Offline sam[PS]
« Reply #9 on: February 28, 2020, 04:55:46 am »
+1
Offline David Hess
  • DavidH
« Reply #10 on: February 28, 2020, 08:56:24 pm »
The power line frequency is low enough that I have never seen it not work even with massively different transformer sizes.  The phase shift is just not that great.
It is not uncommon to do with only one transformer.  A low voltage floating winding can be placed in series or anti-series to buck or boost the voltage of the main winding which would otherwise require multiple taps.
