Author Topic: PAPR (Powered air purifying respirator) power regulation and low battery warning  (Read 363 times)
Offline AxiverseTopic starter
I'm looking at making some PAPRs for some friends in the medical field. In principle it's quite simple, a 12v fans connected to some 18650 batteries. I will add a buck boost regulator to stabilize the voltage from the batteries to the 12v expected by the fans.
I have two things I'm trying to figure out.
1. How do I add some kind of warning light. I'm thinking about putting 4 16850 batteries in series directly and use that into the voltage regulator. I haven't found any modules that will allow me to warn on low voltage on batteries in series. Any ideas what the easiest way to do this is? I have found 1-8s voltage alarms, but those are per cell. I'm not sure how to have the alarm hooked up and have it output 14.7v combined. The regular that I have in mind requires 8V minimum.
2. Do I have to do anything special to regulate the lithium batteries? I know they may discharge at different rates and there is logic in the charging, but is it safe to directly put them in series? How if I wanted longer battery life? Can I put 3 sets of 4 batteries in parallel?
Thanks!
