Author Topic: LSpice to Vero/Stripboard Layout/autorouter  (Read 5138 times)
Offline SirusTopic starter
« on: November 03, 2013, 01:03:27 am »
Could a kind soul recommend a freeware LiteSpice net to Vero/strip board board manual layout or autorouter.
I have loved Veroboards for a long time, and I really don't want to order or make etched boards to my designs unless there in the 20+.
I usually bread board, make the circuit again in Lspice for a record, then spend an age trying to squease it on a veroboard.
There is a theoretical bunch of flowers for the best suggestion, ;P.
TTFN
Online IanB
Re: LSpice to Vero/Stripboard Layout/autorouter
« Reply #1 on: November 03, 2013, 01:10:23 am »
You can get protoboards that have the same strip layout as a breadboard. If you have the circuit built on a breadboard you can then transfer it directly to the protoboard.
Online edavid
« Reply #2 on: November 03, 2013, 01:17:04 am »
Maybe this will help you: http://blog.g4ilo.com/2010/01/stripboard-magic.html
BTW it's LTspice, not LSpice or LiteSpice.
Offline Bored@Work
« Reply #3 on: November 03, 2013, 01:21:00 am »
Blackboard http://blackboard.serverpool.org/ is specifically made for stripboard layout and contains NGSPICE simulation. The problem is the limited documentation.
« Reply #4 on: November 03, 2013, 01:50:31 am »
Cheers B@W,
That's pretty cool, better than what I am using, Can I use a net list and say where to make the cuts?
Just down loaded it, the man needs a medal. and donations! If it could import a Lspice net list and shows where to make cuts, I would give a big donation, no problems.
Bunch of flowers to you B@W.
TTFN
« Reply #5 on: November 03, 2013, 01:56:57 am »
edavid,
Yup, I know it's Linear Technologies Spice. Lite and L is just a software habitual term.
You also get a bunch of flower though. Haven't downloaded it yet but the description looks like it's just what I wanted. Awsome
