Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Projects, Designs, and Technical Stuff
How does this IC work?
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: How does this IC work? (Read 940 times)
fonograph
Frequent Contributor
Country:
on:
November 23, 2018, 06:11:08 pm »
Its supposed to be volume control,in datasheet I found word "resistor ladder",I also found word "amplifier",it have alot pins,wtf is this thing and how does it work?
Is it amplifier? Is it some kind of volume control IC? Is it some weird active hybrid volume morphing op amp gizmo?
Does it decrease volume by passive resistance like potentiometer or is this case of active circuit sorcery?
https://www.google.sk/url?sa=t&source=web&rct=j&url=https://www.mouser.com/ds/2/294/NJW1195_E-69285.pdf&ved=2ahUKEwiT0L7RjuveAhWD6qQKHXHlCw8QFjAAegQIABAB&usg=AOvVaw2OVh08J254k-drNO6JOyzq&cshid=1542996774066
Last Edit: November 23, 2018, 06:13:24 pm by fonograph
Logged
Benta
Super Contributor
Country:
Re: How does this IC work?
Reply #1 on:
November 23, 2018, 06:38:44 pm »
It's a combination of analog switches and digital potentiometers (and associated control logic).
Logged
fonograph
SiliconWizard
Super Contributor
Country:
Reply #2 on:
November 23, 2018, 06:53:50 pm »
Yeah it is much like the PGA2320 except it has additional MUXes to handle 4 inputs.
The volume control itself is basically a resistor ladder and a series of switches. You can get a basic idea with this:
https://en.wikipedia.org/wiki/Logarithmic_resistor_ladder
Logged
fonograph
fonograph
Country:
Reply #3 on:
November 23, 2018, 07:03:07 pm »
Is this passive stepped attenuator with bunch of various matched resistors combined with digitaly controlled solid state relays? Is there some active amplifier in the signal path? Some op amp-ish ouput buffer or something like that...
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
