Yes, that's my proposal. Rationale is to connect each resistor with equal resistance of the involved copper traces. With this layout, each resistor has aprox. equal copper trace length for the main current. To be correct, it's not only length, but resistance of involved copper trace, a function of length, width and thickness - if you keep thickness and width constant, length is to equalized.
Edit: I believe, this layout above is the best solution, trying to combine sense signals, or tapping the outer resistors on opposite sides will bring more copper into the sense path. Copper has worse TC than your resistors and so your measurement will be worse vs. temperature changes.
