have assembled a cascade converter circuit. My main goal is to accumulate a voltage of 80 volts on a C6 1000uf capacitor in about 6-8 seconds. The problem is that I am using a 3.7 V battery. If I assemble a circuit with only one cascade and try to accumulate 80 volts from 3.7, then the energy accumulation occurs very slowly, that is, it takes about 20 seconds, but I have tried to do it with other DC-DC converters and it works, but the only problem, as it seemed to me, is that there should be capacitors with a large capacity between the converters. When I use this circuit, the voltage drops to 2 V instead of 10 volts. What could be the problem? In the peak current of the inductor or in the circuit itself? How else can I achieve this voltage of 80 volts for a 1000 UF capacitor?
