Hi PA0PBZ,
I'm getting an off the shelf 120 watt PSU, i don't want to deal with something like that with my limited knowledge. On your last drawing(I'm wondering what tool you use), the relay should switch between 2 different 24 volt inputs, to a single 24 volt output, and the coil in the relay is driven from a 5 volt source, but that does not really matter, as i wanted to see how much the output line would "sag"/"drop" during the switch over, while the load is 6A.
And i would like to do this with real parts, but my lab PSU is only 2A, i don't have the batteries or the panels or the PSU. This is the reason why i was trying to simulate a relay switchover, so i at least catch the "low hanging fruit" before i buy anything that turns out not to work as i expected.
-lk
