If all you're doing is looking at waveforms, you'll save a lot of time and precision doing it analytically rather than numerically.
SPICE only knows what it knows, on a moment-to-moment basis. If you tell it that it needs those moments to be 1ps or something ridiculous, it's going to dutifully follow your command, and simulate with very small timesteps. Maybe the steps are too small and it doesn't ever recover (timestep too small). Finally, the FT it calculates from that run time, is limited by that run time: frequencies can only be so precisely calculated, based on the data recorded. The true frequency and harmonics might be perfectly spaced, but you get sloppy binned results because it's not an analytical method.
But if all you're looking at is a PULSE source, that's a four step piecewise linear function, a trapezoid wave, with an easily solved integral in its Fourier series. To wit:
- The harmonics go as 1/N from fundamental until the cutoff frequency
- The cutoff is determined by the ramp (edge) rate
- Above cutoff, harmonics go as 1/N^2
- If the duty cycle isn't 50%, even harmonics are present. Specifically, harmonics go as, um, sin(D * (1-D) * N * 2*pi) or something like that. Basically at 50%, they alternate (even harmonics = 0), while at very low or very high D, the waveform is very spiky and harmonics are flat (just as an ideal impulse train has all equal harmonics) until a break frequency F / (D*(1-D)) or thereabouts.
- I'm not sure offhand what happens with dissimilar rising and falling edges, but it must have some intermediate cutoff point. Note that asymmetry in any parameter (rise/fall, on/off) introduces even harmonics.
