Author Topic: AC and DC voltage ratings on pushbutton switches  (Read 815 times)
Offline eecookTopic starter
  • Country: ar
« on: February 08, 2019, 11:38:29 pm »
Hi All,
I was looking for a simulated roller lever type switch on Digikey and noticed that there is a huge difference between the AC and DC ratings for each part. I am wondering why that could be?
Digikey results page: https://tinyurl.com/y52fknbl
The only things that come to mind are:
  1. Tracking.
  2. Finite probability of low voltage switching with an AC waveform.
But neither 1 nor 2 could explain it. Tracking is related to the RMS voltage, doesn't matter if it's AC or DC. Regarding the finite probability, the average switching voltage will be the voltage of a rectified sine wave which is very similar to it's RMS value.
Any clue?
Nullius in verba
Online ataradov
    • Personal site
Re: AC and DC voltage ratings on pushbutton switches
« Reply #1 on: February 08, 2019, 11:57:27 pm »
This is the similar to relays. Connecting and disconnecting AC current is easier, since it naturally goes to 0 very often, so there is no arcing, or arc gets extinguished fast.
Alex
The following users thanked this post: eecook
