Author Topic: Soft soldering stainless steel  (Read 1979 times)
Offline ChristofferBTopic starter
  • Chemistry phd student!
    • My channel:
« on: February 08, 2019, 01:35:33 pm »
So, i'm in need of soldering some very small stainless steel parts together, specificly, 3mm tubing, 1.5mm tubing and hypodermic needle-size tubing.
The entire assembly needs to be insulated in a PTFE ferrule, as it's to be used as an electrode for a micro-flame ionization detector, so joining with fittings is out of the question. Epoxy and such is too.
Is there any flux that would allow soft (Sn97Ag3) solder to do this job, or do I need to silver solder/braze. If the latter, do you think it can be done with a micro propane burner? They get fairly hot and the thermal mass is tiny.
Any input appreciated! Thanks in advance
--Chris
--Christoffer //IG:Chromatogiraffery
Check out my scientific instruments diy (GC, HPLC, NMR, etc) Channel: https://www.youtube.com/channel/UCZ8l6SdZuRuoSdze1dIpzAQ
Offline DTJ
Re: Soft soldering stainless steel
« Reply #1 on: February 08, 2019, 01:56:43 pm »
No practical experience but it seems it can be done
https://sciencing.com/silver-solder-stainless-steel-6144307.html
I've used a micro-burner for silver soldering small parts (non stainless) before.
Offline Conrad Hoffman
    • The Messy Basement
« Reply #2 on: February 08, 2019, 03:56:54 pm »
Maybe it can be done but I wouldn't trust it as far as I could throw it. Can you find somebody to laser or beam weld it?
Online T3sl4co1l
    • Seven Transistor Labs
« Reply #3 on: February 08, 2019, 04:57:40 pm »
Yes, use acid paste flux.
Seven Transistor Labs, LLC
    • My channel:
« Reply #4 on: February 08, 2019, 05:35:08 pm »
Acid paste flux, gotcha. I'll try that. If it doesn't work I might try my luck with those ebay silver solder+flux kits.
I don't suppose dilute hydrochloric acid would work as flux?  That'd be delightfully simple.
Thanks all!
Online T3sl4co1l
« Reply #5 on: February 08, 2019, 07:02:52 pm »
Nah, too cooling, and it doesn't stick around.  Once it's gone, oxides are back.  You can make your own zinc chloride by dissolving the metal in it though.
Offline Domagoj T
  • Country: hr
« Reply #6 on: February 08, 2019, 08:19:57 pm »
Don't dilute it. Dissolve zinc in it, as much as will dissolve (make sure you add little by little zinc and do it outside).
Careful with the final product as it will rust anything it touches and most things in proximity. Again, try soldering outside if possible. Neutralize with sodium carbonate (washing soda).
Online David Hess
  • DavidH
« Reply #7 on: February 09, 2019, 02:03:38 am »
A propane or butane torch is absolutely hot enough for silver brazing using roughly 50% silver alloys.
