EEVblog® Electronics Community Forum
Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Projects, Designs, and Technical Stuff
Which ON/OFF controlled Offline Flyback is best?
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: Which ON/OFF controlled Offline Flyback is best? (Read 1038 times)
ocset
Super Contributor
Country:
on:
December 27, 2017, 04:17:44 pm »
Hello,
The attached are two Offline (230VAC) , isolated, 15V,2W Flybacks.
They both use ON/OFF control with the UCC28C44 controller.
The feedback isolation is done by the digital isolator SI8710.
Which Flyback would give the best Vout regulation?
Do you agree that the one with the BJT current source regulation would give tighter Vout regulation?
SI8710 digital isolator
https://media.digikey.com/pdf/Data%20Sheets/Silicon%20Laboratories%20PDFs/Si87xx.pdf
UCC28C44
http://www.ti.com/lit/ds/symlink/ucc28c44.pdf
Logged
station240
Supporter
Country:
Re: Which ON/OFF controlled Offline Flyback is best?
Reply #1 on:
December 27, 2017, 05:15:11 pm »
One mistake in both circuits, you need to power VDD (pin
on the SI8710 from the aux winding not the secondary. As it is you have a diode junction between primary and secondary halves, this defeating isolation.
Logged
ocset
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Thanking...
EEVblog® Main Site
EEVblog® on Youtube
EEVblog® on Twitter
EEVblog® on Facebook
EEVblog® on Odysee
