Author Topic: M-bus master, subtracting quiescent current from data signaling.  (Read 5136 times)
Offline HSPalmTopic starter
  • Country: no
I'm looking into designing an M-bus master implementation. There are many details to comprehend and implement in the end, but the basics of the signaling between master and slave goes like this (my understanding):
- Bus voltage is nominal 36 Volts
- Master transmits signals by shifting bus voltage levels between 36 Volts and 24 Volts (36 Volts=mark=1 and 24 Volts=space=0).
- Slave transmits by switching in a constant current driver of 11-20mA (quiescent current=mark=1 and quiescent+11-20mA=space=0)
One slave has a quiescent current of N*unit load where Nmax I believe is 4 and a unit load is 1.5mA max. So one slave can have a quiescent current of up to 6mA. If I have 2 of these slaves the bus is already pulling over 12mA, which makes me implement a way of sensing quiescent current on the bus so I know what is signaling from slave or not.
This is a quote from a pdf I found that sums it up:
The
repeater must adjust itself to the quiescent current level (Mark), and interpret an increase of
the bus current of 11-20 mA as representing a space. This can be realized with acceptable
complexity only when the mark state is defined as 36 V. This means that at any instant,
transmission is possible in only one direction - either from master to slave, or slave to master
(Half Duplex).
As a result of transmission in the master-slave direction with a voltage change of 12 V, and in
the answering direction with at least 11 mA, besides remote powering of slaves a high degree
of insensitivity to external interference has been achieved.
My question is if anyone will help me identify an okay implementation, and if maybe a circuit like this has a name already? The available chipsets are for slaves only, and the circuits examples I've seen for masters can only accommodate a fixed amount of slaves within a small range.
The document I quoted is MBDOC48.PDF from the top of this page: http://www.m-bus.com/files/
W4A21021.PDF is the most comprehensive in terms of detailed specifications, but it's listed as "Proposal for new M-Bus Standard"
Online coppice
Re: M-bus master, subtracting quiescent current from data signaling.
« Reply #1 on: March 20, 2017, 11:37:47 am »
As far as I know there is no integrated M-Bus master chip. The production volume of masters is so much smaller than the slaves, nobody seems to have invested in a custom part. Even for the slave chips there is little competition - basically its just TI and On.
One of the M-Bus documents contains a reference design for a discrete M-Bus master, which many people use as a starting point for their own designs. I had a quick scan through the documents at www.m-bus.com, and I can't spot where it is, but its definitely out there somewhere. You might find something by hunting through the TI web site.
The following users thanked this post: HSPalm
Online coppice
« Reply #2 on: March 20, 2017, 12:07:35 pm »
I just remembered that there is a schematic for a very simplistic M-Bus master at http://www.m-bus.com/files/minimaster.tif, which is only suitable from talking to a couple of meters on the bus. That is not what I was referring to in my previous message. There is a schematic for a serious design in one of the M-Bus documents, capable of talking with a large number of meters on the bus.
  • Country: no
« Reply #3 on: March 20, 2017, 04:04:18 pm »
Okay, I've not seen anything more extensive than the one you linked. Thanks for helping out!
I've started on a receiver-circuit that uses a comparator and a sense resistor. The idea is that the same signal is fed into both comparator inputs, only slewed by a low pass filter on the negative input so it will remember the input voltage while the capacitor discharges. Any fast changes in current consumption will show in the direct input, but not in the LPF input, and \so the output only swings with the sudden changes in current.
- R1 is the sense resistor, 0.25 watt, which in worst case must pass 0.5 A.
- R3 and R4 is the voltage divider to bring input signal at least 1.5 V below comparator supply pin.
- R6 is offset adjusting the inputs to make sure the input signal swings past the reference pin.
- R2 and C1 is LPF.
To me this looks like a good design so far, but I want your input... I want it to function at quiescent bus currents from 1 to 64 unit loads, which means detecting 11-20 mA  currents on top of 1.5 mA to 96mA of quiescent current. I'm not quite sure how long a data packet can last in number of bytes, but I want it to receive at least 1 second at a time at 300 baud (sounds sufficient?). Higher baudrates is easier.
I understand that this circuit will not be able to detect bus collisions. Which I must find out if I really need or want.
« Last Edit: March 20, 2017, 04:08:33 pm by HSPalm »
  • Country: no
« Reply #4 on: March 27, 2017, 09:29:07 am »
I finished the design and it works for all three baud rates (300, 2400 and 9600). Does anyone have anything to say about the design before I order a PCB for it? If anything is unclear, please ask. I tried to make the schematic as tidy as possible and using net names for the important signals. In the picture I'm simulating quiescent current of 200mA at 300 baud..
The transmit part is simply switching slave ground connection though a 12V zener to subract 12V from the overall bus voltage.
« Last Edit: March 27, 2017, 09:30:50 am by HSPalm »
Offline jbb
« Reply #5 on: March 27, 2017, 07:37:36 pm »
Hi HSPalm
I think you can do a bit better without too much trouble.  I thoroughly recommend using a differential amplifier across your high side shunt resistor (or a current shunt amplifier or an instrumentation amp...).  This way variations in your 36V supply won't look like comms traffic.
In fact, with a little more fiddling, you can integrate your voltage regulation and transmit mark/space generator into (see first image) a single stage.  This might be able to do full duplex (if you can compensate for the cable capacitance).  Keeping the ground continuous can also be helpful.
Alternatively (second image) you can move your sense resistor to the ground rail.  Provided R1 is small (like <1V drop at max current) you can make sure that M1 is fully switched on even when its source is a little above 0V.
The use of a high-pass behaviour for separating the slave marks and spaces could become a bit challenging depending on how much traffic you have.  Also long cables have a tendency to have high capacitance, which will cause current peaks and dips while your master transmits marks and spaces (because i = C dv/dt).
If you want a really reliable solution I suggest an ADC to measure the current and a bit of software to a) learn the base load, b) learn the line capacitance and c) compensate for line capacitance dv/dt currents.  You could put this in a small micro on the M-Bus side of your isolation barrier and include features like reporting the base current and temperature/health monitoring.
  • Country: no
« Reply #6 on: March 28, 2017, 08:39:47 am »
Hi jbb,
Thank you for your suggestions.
Do you mean to replace the comparator with a differential amplifier, or put an amplifier between the shunt resistor and the comparator inputs? I like the idea of amplifying the signals so I don't operate so close to the comparators capabilities. Can you recommend a "jellybean" part for the differential amplifier?
I've considered this, but I'm restricted to using no electronic brains, other than the TTL UART I'm feeding. By measuring the current with an ADC and an mcu I could do all sorts of things, like fault detection and collisions detection.
Offline jbb
« Reply #7 on: March 28, 2017, 07:07:45 pm »
Hi
If you've got no chance to hang a micro controller out there, I suggest you kill two birds with one stone.
I suggest you put a diff amp. between the shunt resistor and the comparator.  A basic part like an LMwhatever + matched resistors would probably hit the spot. Or a current sense amplifier with bandwidth > 200kHz (TI, LT and others sell them).  Or you can just move the shunt to the low side if you don't need a solid ground rail.
If you band-pass filter the output of the diff amp or low side current shunt, you can ignore the base load.  Set the high-frequency cutoff to remove noise, and the low-frequency cutoff to only pass the edges of the  receive signals.  This will output a train of short pluses corresponding to mark->space (+ve) and space->mark (-ve) transitions.  They use a comparator with generous hysteresis to convert these pulses into nice square output signals.
Hope that's useful.
Offline niu_yx
  • Country: cn
« Reply #8 on: January 22, 2019, 07:12:50 am »
HI,HSPalm,Can you share your final schematic? How much load can I bring?
