Author Topic: Magnetic switch inside a dive light  (Read 230 times)
Offline e100
« on: October 25, 2020, 02:10:50 pm »
Has anyone pulled apart a reasonably modern waterproof dive light to reveal the switch mechanism?
Some have a rotary control that wraps around the body like the focus ring on a camera lens, other have a rotary control perpendicular to the body.
Is it a reed switch (or series of switches) or a magnetic sensor IC or something else?
Offline geggi1
Re: Magnetic switch inside a dive light
« Reply #1 on: October 25, 2020, 02:19:12 pm »
most likely is it a Reed switch with a transistor or relay driver.
https://www.pickeringrelay.com/what-is-reed-relay/
Offline free_electron
    • SiliconValleyGarage
« Reply #2 on: October 25, 2020, 03:31:54 pm »
All the light & motion lights use hall sensors Allegro 3 pin sot23
Offline Doctorandus_P
« Reply #3 on: October 25, 2020, 07:55:13 pm »
I happened to have a HALL sensor stuck in a breadboard in front of me, so I put a DMM in it's power supply.
It constantly sucks over 3mA from the power supply, which is not a very good thing for a battery operated gadget. REED switches do not need any power to preserve their state.
« Reply #4 on: October 25, 2020, 08:57:54 pm »
light and motion uses a very low power mcu ( gecko) and they pulse the power of the hall sensor a few times per second for a few microseconds.
Offline drvtech
« Reply #5 on: October 25, 2020, 11:41:20 pm »
You can get MUCH lower power Hall effect switches. Look up DRV5032. Less than 1uA under certain conditions.
