Thanks for all your help guys, I have gained a lot from this. Now I know what these PSU's are called I
have been doing a bit of research.
After a google of capacitive reactance, I found a free usefull and small program/calculator that does
this and some other handy stuff, sorry if you all know about it. Electronics Assistant v4.31.
Sorry not noting anyones name, I am using notepad to type this out as forums usualy drop out on me when
I submit
It just so happens, that one of the failed units was a radio controled mains switch with a manual button
on the plug pack. I have 4 of them. They have loads of room for my custom boards in my simple projects
below. I looked a little bit deeper on the board and found that they are using the 2 stage method some
one mentioned, They are using a double drop type of zener regulation, at first I thought they where
using a half wave rectifier, but it is full wave, but 2 diodes are 24v zeners.I thought that was quite
smart as that should double your power rating also, then for the logic a 5v Zener after that.
I striped the dead one for parts and tested them against a working one. I couldn't test the 24v Zeners
in reverse as my power supply only goes up to 20v but they test good forward. I also checked the mains
cap esr's, they where quite close. so I just swapped the mains cap and 24v zeners on the working one, and
it worked fine. So I baged up the PSU parts, labeled it Tranformerless kit 240ac to 24v, 35ma and put it
in the new draw in the part bin
I think the fail must have, as some one mentioned, transients ripping the logic or a transistor on the
board.
As these are going to be usefull as project cases I didn't dig any further, I am using one for my desk
light, but I may kill it as its a nice case, lol.
The projects I was hoping to build from this type of psu are..
Timed once only Mains switch--
This is to turn my 5 & 7 year old daughters bed blankets off after 30mins, so I don't cook them. I
forget to set my alarm 50% of the time, don't worry, waterproof sheets just to be on the safe side. They
haven't done that since they where 3. Might even make another 2 for our bed, as we often forget due to
drifting orf to nodland.
Plug in the wall Power failure lighting--
We have had a dodgy mains feed to our street for around 2 years now. So if the power goes, we are
plunged into darkness, my youngest get quite distraught because of that bang of silence and sudden
darkness. And I get really peeved while finding the ladder in the dark. Using some rechargeables and
bright leds in one wallwart type box, I might even get flash and do it all with diodes, resistors and
the mains and smoothing cap. I am making a heavier duty 12v backup system for the fridge and freezer, I
was also thinking of rerouting the house lighting circuit through a UPS, anyhow that's all another story.
DIY suse vide controller--
My only concern on this would be the temperature sensor, it is waterproof but I was thinking of earth
grounding the metal tube it is epoxyed in for belt and braces.
Using an arduino, been trying to make one for 2 years now. In the beginning I was trying to figure out
thermal mass and the delays involved to make some kinda formula, then around a 3 months after I found
out about PID control, HALLELUIAH, learned all of that then discovered adafruit do a kit based on
some bodys library's 3 months later, using a long timebase PWM. I am already to go on this using just the
library's the fella made, my program and hardware.
TTFN
