Hey, All I am building a sensor board using a 16 port RJ45 and wondering if some of the specs that I am using are correct before I send out my Board for production.
Board: 1oz Copper
Trace Size: .254mm
Power Trace Size: .5mm
GND is filled on Top and Bottom.
Power is coming in from an ATX power Supply using the 6 pin that goes to Data connection allowing for +3.3v,+5v, 12v, and GND.
I have the Schematic and PNGs of the board attached.
