Author Topic: Mains current measurement with Halleffect sensor?  (Read 1210 times)
Offline Windows9ProfessionalTopic starter
  • Country: at
« on: September 15, 2019, 11:31:40 am »
Since I own a scope, I kind of always wanted to measure mains current. Today I asked myself, If it would be possible to make a reasonably accurate current sensing extension cord with a BNC connector for my scope.
Now I just wanted to ask, If measuring current with a halleffect sensor has any flaws, or is as easy as it sounds like
I already created a list for the components I need:
One cheap extension cord (with phillip screws)
A halleffect sensor
A BNC connector
a powersupply for the sensor (probably some 12VDC LED power supply which I will hide inside the extension if possible)(and also a accurate voltage regulator)
I already have the coil, but I'm not quite sure if 15 turns of 1mm insolated copper wire around a 1cm (diameter) ferrite core will do it. It generates near to no heat at 5A continuously.
So, is this as easy as it sound or are there some flwas in my plans?
« Last Edit: September 15, 2019, 11:33:16 am by Windows9Professional »
Offline MagicSmoker
Re: Mains current measurement with Halleffect sensor?
« Reply #1 on: September 15, 2019, 11:35:53 am »
Flaws? Well, the Hall effect sensor requires power and a bog standard current transformer doesn't. You do get better high frequency bandwidth from the H.E. sensor if you are interested in the harmonic distortion of a load, but otherwise the current transformer is overwhelmingly preferred here.
EDIT: wait, whut?
What coil are you talking about here?
Online Kleinstein
« Reply #2 on: September 15, 2019, 11:41:39 am »
The system with a hall effect sensor works about as describes. The main downside of Hall effect sensing is that near by iron or other magentic material can effect the reading and there can be an offset, as the hall voltages are quite small. The sensor-circuit man also pic up some other signals.
For AC current, there is an even simpler variation, with a current transformer. This does not even need a power supply. Clamp on amp-meters work this way.
A 3rd way for measuring is a Rogowski coil - kind of inductive pic-up without a core. However this usually needs amplification signal forming.
  • Country: at
« Reply #3 on: September 15, 2019, 11:42:32 am »
Thank you for your quick reply.
With flaws I meant something like f.e. a HES has non-linear output (which it luckily hasn't)
Yes, I am more or less interested in higher resolution
So, thank you for your reply
  • Country: at
« Reply #4 on: September 15, 2019, 11:48:13 am »
Like really low power signals (like RF) or nearby power lines in the wall?
A current sensing transformer would only work with AC and I planned to calibrate it with DC
I don't think I will go with the 3rd option, just because it is more complicated
Thanks for your reply
  • Country: at
« Reply #5 on: September 15, 2019, 11:53:07 am »
EDIT: wait, whut?
Some copper wrapped around a ferrite core (not that one out of a transformer, just a ferrite stick)
But I can easily increase the turns on it if the magnetic field wouldnt be strong enought
Offline MagicSmoker
« Reply #6 on: September 15, 2019, 01:15:37 pm »
This makes no sense, really. A mains-frequency current transformer won't need calibration since its output will be as precise as the value of the burden resistor and the turns ratio, and will range in price from 3-15 Euros depending on form factor and current range. For example, this part from Triad Magnetics has a 1:500 ratio and max primary current of 30A for $3.37:
https://www.digikey.com/product-detail/en/triad-magnetics/CSE187L/237-1103-ND/242546
Just wire a burden resistor across the output to convert the secondary current into a voltage and read directly with your scope. For example, a 50 Ohm burden resistor will give 3V out with 30A through the primary. Easy-peasy.
  • Country: at
« Reply #7 on: September 15, 2019, 04:44:59 pm »
... Oh, you're right.. To be honest, I didn't notice that bevore...
Does a CST blur out all detail of the current waveform or is there at least some detail? (f.e. when measuring a switch-mode power supply, there's some switch noise as far as I know)
Edit: the example above is bullshit... I mean when measuring f.e. an iron-core transformer
« Last Edit: September 15, 2019, 04:47:20 pm by Windows9Professional »
Offline schmitt trigger
  • Country: mx
« Reply #8 on: September 15, 2019, 05:00:15 pm »
The downside of a CT, is that it can’t measure DC, or AC with a DC component. Otherwise they are very sturdy and don’t require external a power  source.
Cheap CTs will also have some bandwidth limits, but there are good wideband CTs, although they are not cheap.
https://www.pearsonelectronics.com/
To your idea of hall-cell sensing; Allegro Microsystem and others already have such devices. The beauty of such devices is that it incorporates the features and processing circuitry required to make an accurate IC current sensor.
« Last Edit: September 15, 2019, 05:02:02 pm by schmitt trigger »
Offline MagicSmoker
« Reply #9 on: September 15, 2019, 09:53:25 pm »
Does a CST blur out all detail of the current waveform or is there at least some detail? (f.e. when measuring a switch-mode power supply, there's some switch noise as far as I know)...
The cheapest current transformers with plain old laminated silicon steel E cores (like the one I linked to previously) won't have terribly high bandwidth so wouldn't be ideal for observing the waveform into something that draws peaky currents with high harmonic content, like a switcher. If that's what you want to do then a Hall effect sensor intended for mains applications like the ones from Allegro that @schmitt trigger mentioned would be better.
