Hi
I've got a main PCB with a pin header and I want to connect a second PCB to it, but because of the design, that PCB is quite "far away" (about 15 / 20 mm).
Ideally I would like to avoid using a cable, but rather have a simple pin header on the daughter board which will connect with the pin head on the main board.
Any ideas on how to raise or find a very high connector?
Thank you!
EDIT: ok sorry I spoke too fast, after a quick search it seems that the way to go is a simple through-hole female header (the header on the main board is 1.27mm) with long pins like that.
But then what about the assembly (for production), can the header be mounted at a specific height? It would probably need a custom plastic part underneath to mount it at the correct height, no?
