Induction motors do not have an intrinsic voltage. They have a soft saturation volts per hz limit.
A 400v 50hz motor is going to be producing 800 volts at 100hz, if you let it.. that is if you need it to. Torque follows the volts per hz squared
A european 380v 50hz motor at 50hp is an american 480v 60hp 60hz motor.
Thank you again for you reply. And for helping me better understand it.
400V/50Hz =8V/Hz , then 8V/Hz×100Hz=800V that's 6000rpm for a 2-poles motor. And the same ratio could be applied to switch calc. between European and US motors.
If we capped the motor/engine to 4000rpm top speed, it would mean
67 Hz 73 Hz with the safety margin, and
533 V 578 V. This would greatly limit the VFD options..
The torque for the Baldor motor is approximately 60.73 Nm, which means the breakdown torque will be around 120, while the engine torque could reach 185-210 Nm. So it might not be a good fit for this engine.
Going back to
Berni replies, a synchronous generator could indeed save me a lot of troubles, especially that I need less than 100VDC and couple of amps to control it and I would still need the load bank..
It seems to be hard to find synchronous motors that have such high speeds, and motors at that power and torque seems to be too expansive, but perhaps I am assuming wrong, here are two example motors:
75kw 6000rpm is 119Nm/75kw 5500rpm is 130Nm: $6K
132kw 5500rpm Torque is 229Nm: $9K
