Tim,
Thanks for the comments.
I'm working on a revised PCB do deal with coupling issues. Having JLCPCB available to make prototypes has been such an opening for me to make various things - for it's a lot easier than breadboarding because for one thing I'm blind in one eye and with age I need a lot of light when I do things and I can do this part on the computer screen.
How is this any different then the jillions of wires spewing about in an AA5? I know, everything is closer together in many of them. Also, at one point I had shield wires on the IF and the VC but something was wrong and I removed it. I will put it back but this time I'm going to do it sequentially instead of changing too many things.
The signal isn't coming in from the mains, it's coming from my series of two stretched "Slinky" antenna at the apex of my garage roof outside. I will probably have to make a trap on the antenna.
At one point it was receiving other stations, but something has changed or went out.
I wonder if the distortion was influenced by a heterodyne of this signal that was bypassing the IF and being out of phase it might have been fighting the normal signal that comes through the mixer and IF.
I ordered a set of IF transformers from Surplus Sales of Nebraska.
https://www.surplussales.com/INDUCTORS/pdf/ti-13-pc1.pdfI really don't like the slug tuned type with top and bottom entrances, I prefer the old dual capacitors on top style but if it work I'll be fine with it - it lends more to the hobbyist nature of this set.
They're NOS so I'll have to inspect them carefully.
Someone asked why I didn't make a nice old style cabinet. The nature of this set is that I designed this from a culmination of various AA5 schematics, located all the various parts, calculated and hand wound the antenna coil and later remade it on a PCB board which I also designed all from scratch. Building this self-teaches me various things which most people have learned in a classroom. I'm not a student of any school except the hard knocks of living. I've been tinkering with electronics since 5th grade and I'm 59 years old.
I've been an SWL'er since childhood and got into Ham Radio in my 20's. My day job is computer programming in a data acquisition environment (which calls for a certain amount of electronics - I also design interface boards at work). Then I got into making Tin whistles as hobby/business for about 20 years and I did less with Electronics during that time except for a lot of Audio frequency calculations for the toneholes.
I built a 3D printer from scratch with the Reprap, Prusa I2 design as the baseline.
And with the past two years the electronic bug has come back and I've built some Amplifiers, a preamp and I wanted to get a better understanding of tubes and there is a lot more stuff and materials available in Radio to do just that.
This has been my own "self-taught" way of learning things, I give my a project and then I work on it. I also write software at home to keep the creative juices flowing and I keep ahead that way.
