Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Projects, Designs, and Technical Stuff
tek 453 scope mod
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: tek 453 scope mod (Read 951 times)
m3vuv
Super Contributor
Country:
tek 453 scope mod
on:
March 17, 2018, 10:49:56 pm »
hi all ive a tk 453 scope ive repaired,just out of interest it has a nuvistor front end,just wondered if anyone here has converted one to a fet front end ,dont need to but may be an option if a nuvistor dies,cheers m3vuv.
Logged
JohnPen
Regular Contributor
Country:
Re: tek 453 scope mod
Reply #1 on:
March 18, 2018, 09:10:02 am »
I haven't converted the Y amp front end nuvistors but have replaced the A timebase nuvistor with the FET equivalent as per 453A. This came about when the A TB nuvistor failed, proved by nuvistor swapping, plus an associated tunnel diode failure. I did look at replacing the B timebase nuvistor but as that one was OK I left it alone. I did investigate whether to update the front end circuitry to FETs but decided to leave well alone. To modify the existing Y board would be quite complex whereas the TB changes were easily modified on the existing TB board. Probably one should create a small PCB with the 453A FET circuitry on it and then replace the nuvistor related components. Maybe someday but I hardly use the 453 these days as it is very much a backup scope in case my regular scope has a problem.
John
Logged
m3vuv
Super Contributor
Country:
Reply #2 on:
March 18, 2018, 09:28:57 pm »
yup i think i will leave well alone for now,im like you i have an hitachi scope i normaly use,so im using the principal if it aint broke dont fix it.73 m3vuv.
Logged
Cyberdragon
Super Contributor
Country:
Reply #3 on:
March 18, 2018, 11:22:31 pm »
Nuvistors apparently have a 50,000 hour life, don't mess with them.
Logged
*BZZZZZZAAAAAP*
Voltamort strikes again!
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
tek 453 scope mod
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
