Author Topic: Can anyone identify this connector  (Read 1371 times)
Offline Simon
  • Global Moderator
    • Simon's Electronics
« on: April 22, 2015, 06:54:23 am »
I have been shown a pump (usually aimed at marine applications) with a type of connector we have never seen. We'd need to find the mating half so I'm wondering if anyone has ever used one or know what it is. pictures attached. The thread is a 3/4-20 UNEF-2A
https://www.simonselectronics.co.uk/shop
Varied stock of test instruments and components including EEVblog gear and Wurth Elektronik Books.
Also, if you want to get ripped off: https://www.ebay.co.uk/usr/simons_electronics?_trksid=p2047675.l2559
Online Marco
Re: Can anyone identify this connector
« Reply #1 on: April 22, 2015, 02:20:33 pm »
Tepas is non responsive?
Offline Pillager
  • Country: at
« Reply #2 on: April 22, 2015, 06:41:36 pm »
Looks like a standard round DC-connector with a thread to secure it (and for waterproofing). In that case it should match a normal round plug of the right size.
I've seen something similar (just in plastic, for those outdoor LED strips).
What dimensions are we talking about here?
Greets
Tom
« Reply #3 on: April 22, 2015, 09:16:25 pm »
Looking at the voltage and the thread style I will look at the circular threaded military connectors made by Amphenol, Socaplex or other suppliers, as this lloks like an aircraft part. If not then they will have a socket and plug that will fit the 4 mounting holes and which will handle the 20A of current.
