I live in Tokyo and have a Japanese domestic market (JDM) shop vacuum. It has a very useful feature where a corded tool, when plugged into the provided power receptacle on the front, will start the vacuum and then it will shut itself down after a 5 second delay. I use several cordless tools though, and although the newest tools from Makita use a ridiculously overpriced Bluetooth system to emulate this behaviour, this vacuum and the tools I use (primarily a Festool Tracksaw which supports an incompatible Bluetooth system anyway) do not have any support for this.
The Goal:
Use a cheap Chinese wireless dongle to remotely start and stop the Vacuum.
The Challenge:
Internally the circuit board that governs the entire operation including the current sensing system is completely potted, so I can't just tap into the existing trigger circuit as I had hoped. All external wiring from the board to the switches and outlet are at line voltage and carry full current. I want to avoid using some kind of switched main outlet as the vacuum can draw as much as 20A when it is supplying power to my bigger saws, and it's just inelegant.
The Proposal:
The outlet on the front (Tokyo is 100v/50Hz) that does the current sensing is live when in the "automatic" mode. It requires ~10-20 watts of current draw before the vacuum will turn on, it turns off after a 5 second delay when the load is removed (this is intentional as it completes the dust extraction.) My thinking is that if I create a dongle that:
1) Plugs into the automatic outlet which provides power
2) When triggered by the remote, puts a purely resistive load, just enough to trigger the vacuum
3) After creating the load required to start the vacuum, it goes open circuit (no load) for ~4 seconds before again drawing current to keep the vacuum on
My thinking is this switching avoids drawing a continuous load and all the heat and safety issues that would result from that.
The Resources:
A Chinese wireless key fob and 4-12vdc based board with small relay (7A @ 120v, would prefer it to be running low voltage...)
A potted 12vdc 0.45A power supply that is low enough draw to not trigger the vacuum when plugged into the automatic outlet
Multimeters, Oscilloscope, soldering station and everything required to make a circuit board.
Easy access to Akihabara for parts
The Request:
I'm a bit of a newb, I understand a lot of the fundamentals but I don't like playing with line voltage without some adult supervision (it really is 100v here, not 110 or 120 here if that matters as far as design.)
My expectation is that there would be a straight forward design that uses a transistor capable of handling 100v that gets switched on by the relay from the remote to drive a simple circuit that shorts across a large current limiting resistor, while a timer (maybe a capacitor?) modulates that connection so it is very momentarily engaged every 3 or 4 seconds. The short across the resistor would be fused so if something went wrong it would just blow 'open' rather than create a smoking ball of death...
Is there something 'off the shelf' that does this, or is there a better approach given the conditions outlined above? I'm hoping to get some help with the design, and learn some basic solid state switching of 'high voltages' along the way. Any of you able to advise?
