I am trying to measure the voltage across a burden resistor attached to a current-sense transformer using a differential ADC.
The current sense transformer will operate at ~250 KHz.
My current design is based on Figure 2 on page three of "Driving High-Speed Analog-to-Digital Converters" (
https://www.ti.com/lit/an/slaa416a/slaa416a.pdf) from Texas Instruments.
I am planning to use the ADC10065
1) Is tying the COM pin to an external reference bias voltage the correct way to interface the ADC10065 with a current transformer?
2) Is there a better way to measure AC voltages from a current sense transformer?
/?action=dlattach;attach=1799654;image)
