Either these don't exist or my Google-fu is fading... so last resort try the good denizens of EEVBLOG
I'm looking for a low profile panel mounted vandal-proof IP66 or greater rated pushbuton (non illuminated) in the style of the picture below - but just the mechanical actuator. The idea is there will be a PCB mounted just behind the panel with either a tactile switch or microswitch on the PCB itself. I want to avoid cables & connectors, and I know some switches have PCB pins for direct mounting although I'm not too keen on that especially for something that is likely to get thumped in its lifetime.
I know there are modular switches which utilise a clip-in microswitch as part of the switch assembly but that's not what I'm looking for, I'd like the two parts to be seperate.
Any ideas welcome, thanks
