Author Topic: Video input converters. PAL/NTSC to MIPI CSI-2  (Read 3781 times)
Offline TinkerladTopic starter
« on: March 01, 2019, 01:55:08 am »
Hi guys,
Got a quick question regarding IC selection. I am trying to add analogue video input to a raspberry pi like device for a project I am working on.
This device has a standard pi header, as well as the CSI input.
My analog video can be either NTSC or PAL.
My intent originally was to get a one chip solution to convert from PAL/NTSC to MIPI CSI. I found the ADV7280-M. This chip is perfect in all aspects bar one.... It costs AUD$14.66 in single quantity.....
The other thing with this chip is that it offers 8 analog inputs to switch between.... This is something I dont really need.....
I had considered using something like a TVP5150AM1 then a FPGA to translate the parallel  8-bit ITU-R BT.656 format into CSI. but am still new to this field and would have to spend a very long time working this out....
So my question is, has someone done something like this before and/or can recommend a cheaper option? I am open to using either CSI or another input method. I am also not objecting to using intermediary formats and multiple ICs.
Thanks, and I welcome your guys thoughts.
Offline NiHaoMike
    • Facebook Page
Re: Video input converters. PAL/NTSC to MIPI CSI-2
« Reply #1 on: March 01, 2019, 03:16:55 am »
How about a USB video capture gadget?
« Reply #2 on: March 01, 2019, 04:35:10 am »
The problem I have with that is that the bandwidth is incredibly low... USB2.0 gives a theoretical maximum of 480Mb/s while CSI has a theoretical of 1Gb/s (realistically achieving ~800Mb/s) per lane. The device like the pi has two lanes available.
For PAL/NTSC at an 8bit resolution the video bandwidth alone is ~310Mb/s
At 10bits/pixel this goes to ~370Mb/s
As the device muxes all of the usb ports to a single port on the SoC this would limit me to 1 video stream maximum assuming nothing else is hogging usb bandwidth. This same problem arises on the Pi. This is shy I would like to use the CSI header....
Offline Cezane
« Reply #3 on: May 02, 2022, 07:54:44 pm »
I'm also interested in the exact same solution. Did you find any other solution for video analog to CSI? or other IC than ADV7280-M?
