Likely you will start having contact failures after few months to years.
Unfortunately the mating board is already done, it's ENIG.
Then tin the pads and thoroughly clean from flux. Although I don't advise using connectors of such style (springy) in non gold plated variants. If you want to go with tin, use connectors which strongly bite into solder on the pad. Such as commonly used in HDDs.
